Thread: John's Alu Profile build
07-04-2020 #11
There's nothing wrong with rails on the rear plate, I've built dozens of machines using both methods and neither is better than the other because the difference between them is hardly anything and any advantage one as over the other is mostly dependant on machine design and user needs.
In your case with a short Z-axis, it's the best method because it allows you to make the most out of a short-stroke while allowing you to keep the gantry low and squat giving the best strength.
Edit:
Don't worry about the profile it will be fine. If you using my "L" Gantry design just make sure you bolt it together well.
Aluminium profile cnc build
By valdis034 in forum Gantry/Router Machines & BuildingReplies: 84Last Post: 21-02-2023, 02:27 PM -
BUILD LOG: First Build - Yet Another Alu Profile Router - 900 x 800
By CaptainBarnacles in forum DIY Router Build LogsReplies: 53Last Post: 14-02-2020, 08:16 PM -
BUILD LOG: Large aluminium profile build
By jeronimo in forum DIY Router Build LogsReplies: 6Last Post: 12-11-2016, 10:02 PM -
BUILD LOG: New build - fixed gantry mill using extruded profile
By toolchimp in forum DIY Router Build LogsReplies: 3Last Post: 09-11-2012, 04:10 PM -
NEW MEMBER: John C, York, UK
By JohnC in forum New Member IntroductionsReplies: 1Last Post: 17-10-2010, 07:03 PM
