    [QUOTE]I treated it once with a PVC based sealer and water and this has cut this down. I will aim to treat it once more before moving on with the block work next week. This should also help ease my mind around bonding to the floor, I was more than a little concerned that it wouldn't bond correctly due to the dust but I'm told this is a commonly used solution to aid bonding.
    [/QUOTE
    Looking good, I take you meant PVA or even better is SBR
  2. The Following User Says Thank You to Clive S For This Useful Post:
  1. Aluminium profile cnc build
    By valdis034 in forum Gantry/Router Machines & Building
    Last Post: 21-02-2023, 02:27 PM
  2. BUILD LOG: First Build - Yet Another Alu Profile Router - 900 x 800
    By CaptainBarnacles in forum DIY Router Build Logs
    Last Post: 14-02-2020, 08:16 PM
  3. BUILD LOG: Large aluminium profile build
    By jeronimo in forum DIY Router Build Logs
    Last Post: 12-11-2016, 10:02 PM
  4. BUILD LOG: New build - fixed gantry mill using extruded profile
  5. NEW MEMBER: John C, York, UK
    By JohnC in forum New Member Introductions
    Last Post: 17-10-2010, 07:03 PM
