Thread: John's Alu Profile build
10-09-2020 #34
Why did you epoxy the whole base.? You will need a base board or fixture plate and that will need to be surfaced so it seems like a lot of wasted epoxy to me.?
To me sitting the rails on profile to raise the gantry defeats the point of the concrete base as it introduces a weak point which could have been avoided by creating raised sides by shuttering up and filling with concrete, then epoxying just the raised surface. You could have then fit tooling plate to the surface for the rails to fasten too, it could also have been used to fine tune out any errors.
But I suppose the beauty of concrete is that you could still do something like this if you wanted without too much hassle.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Aluminium profile cnc build
By valdis034 in forum Gantry/Router Machines & BuildingReplies: 84Last Post: 21-02-2023, 02:27 PM -
BUILD LOG: First Build - Yet Another Alu Profile Router - 900 x 800
By CaptainBarnacles in forum DIY Router Build LogsReplies: 53Last Post: 14-02-2020, 08:16 PM -
BUILD LOG: Large aluminium profile build
By jeronimo in forum DIY Router Build LogsReplies: 6Last Post: 12-11-2016, 10:02 PM -
BUILD LOG: New build - fixed gantry mill using extruded profile
By toolchimp in forum DIY Router Build LogsReplies: 3Last Post: 09-11-2012, 04:10 PM -
NEW MEMBER: John C, York, UK
By JohnC in forum New Member IntroductionsReplies: 1Last Post: 17-10-2010, 07:03 PM
