I particularly liked the shot of one of the girls sorting bearing rollers - having put it in the "fully electronic" measuring machine, a little torch bulb lit up over the correct bin to put it in! Just a series of bare bulbs that looked as if they were soldered to wires taped to the back of the bins.
My own lathe is a Smart and Brown that probably dates from about the same era. I've had a couple of covers off bits of it for adjustments and the complexity of the mechanical bits internally is horrendous. The knob on the saddle that switches between surfacing and sliding movement drives the internal clutches via a couple of pairs of bevel gears and a rack and pinion. I'm sure that they could have designed something a bit simpler to do the same job - but I must say that it is a real delight to use even if it is around 50 years old.
FOR SALE: Colchester 3250 Lathe- Peterborough
By Callum in forum Items For SaleReplies: 0Last Post: 10-03-2017, 03:16 PM -
New toy: Setting up Colchester Student lathe
By Jonathan in forum Milling Machines, Builds & ConversionsReplies: 49Last Post: 09-04-2015, 04:17 PM -
Whats it worth, Denford Mirac CNC Lathe
By Dean jeffery in forum Marketplace DiscussionReplies: 4Last Post: 03-07-2014, 01:38 PM -
Colchester Chipmaster Lathe HELP !!!
By snookaman in forum Lathes, Lathe Rebuilding & ConversionsReplies: 2Last Post: 28-08-2013, 10:23 AM -
I'm thinking of bidding on a lathe , what do you think it is worth ?
By Fivetide in forum Marketplace DiscussionReplies: 17Last Post: 22-09-2012, 10:50 PM
