Thread: Losing steps/position, again
07-04-2020 #10
That's WRONG information your giving out, the drives don't regulate the voltage they regulate the current. 70Vac which is 98Vdc would destroy those little motors in no time at all. It would also make them run like a bag of shite.
You cannot stick any voltage you like into a stepper, there is a limit where it starts to have very negative affects. Namely iron losses and motor heating which kills them.
Those Large voltage Ac drives are only really any good for larger steppers Like Nema 34 or very high inductance NEMA 23's. Your typical 3-4Nm 4.2a Nema 23 with 3-4mh inductance doesn't like to be run much more than 80vdc and at that, you are pushing them past there design threshold so are shortening there life.
For the NEMA 23 motors, which this machine will have fitted he'll only need drives with a max rating of 70Vdc and would run them around 55-60Vdc. Or 50Vac drives running at 40-45Vac.
Losing steps
By Edendale in forum General DiscussionReplies: 11Last Post: 06-03-2020, 10:10 PM -
Weird noise on travel and losing position
By ngwagwa in forum Artsoft Mach (3 & 4)Replies: 12Last Post: 07-02-2020, 05:45 PM -
Router losing steps. Solution needed. Will this help?
By cncbobuk in forum Chinese MachinesReplies: 9Last Post: 27-12-2017, 03:40 AM -
Losing steps on Z axis
By Arzo10 in forum Machine DiscussionReplies: 15Last Post: 31-03-2017, 10:49 AM -
New Mill losing steps
By lukecnc2012 in forum Gantry/Router Machines & BuildingReplies: 42Last Post: 08-11-2014, 02:56 PM
