Thread: Losing steps/position, again
08-04-2020 #10
This would be better. 625Va is too much and you could run into issues with in-rush trips. 500Va is plenty and like I said you could get away with 300Va but doesn't leave much upgrade room.
However, you must wire in parallel, not series because you'll have 70Vac in series which will give 95Vdc + when rectified to DC and that will produce Magic smoke from those drives.!
If you want to go with series wiring then look for 2 x 20V 500Va. This will give aprox 55Vdc
Choice is yours.!
I noticed earlier you linked to Bridge and Caps. The bridge is correct but the Caps are wrong. 330Uf is far too low
You want to be looking for 3 x 100V 4700Uf. You could use 4 but 3 will work fine.
https://airlinktransformers.com/prod...rmer-cm0500235
Losing steps
By Edendale in forum General DiscussionReplies: 11Last Post: 06-03-2020, 10:10 PM -
Weird noise on travel and losing position
By ngwagwa in forum Artsoft Mach (3 & 4)Replies: 12Last Post: 07-02-2020, 05:45 PM -
Router losing steps. Solution needed. Will this help?
By cncbobuk in forum Chinese MachinesReplies: 9Last Post: 27-12-2017, 03:40 AM -
Losing steps on Z axis
By Arzo10 in forum Machine DiscussionReplies: 15Last Post: 31-03-2017, 10:49 AM -
New Mill losing steps
By lukecnc2012 in forum Gantry/Router Machines & BuildingReplies: 42Last Post: 08-11-2014, 02:56 PM
