Thread: Chinese Spindle setting Help
Nobody can tell you that with any accuracy because there are far to many variables involved. The tools you will be using and cam strategies your using will dictate most of this and only when you start using larger tools that spin slower and require more torque will you possibly need to start messing with torque tuning the VFD.
Cutting 6061 or most aluminum for that matter unless cutting with large diameter tools 12mm + will require high spindle speeds which is where your highest torque is on these spindles so I wouldn't worry about messing with torque settings or minimum speeds.
I pretty much exclusively cut aluminum and I rarely drop below 12000rpm and if using adaptive stratergies then I'm in the 15-18,000rpm's with 6-8mm 3 flute cutters.
Only with 12mm will I drop to 9-10,000rpm.
If it's working correctly and giving correct speeds at the commanded frequency then just leave it well alone and start making chips is my advise.
Setting up new spindle
By Hercules in forum Generic Chinese SpindlesReplies: 3Last Post: 10-12-2019, 01:18 AM -
Chines Spindle and VFD setting of my Estops can any one help (EMI i think)
By Slasher102 in forum General DiscussionReplies: 7Last Post: 27-04-2019, 03:51 PM -
setting axis A in spindle mode
By ladybreaker in forum Artsoft Mach (3 & 4)Replies: 9Last Post: 09-12-2018, 11:35 AM -
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
setting up Moeller VFD to chinese spindle
By routercnc in forum Spindles & Drive MotorsReplies: 16Last Post: 16-02-2011, 08:22 PM
