If you have dust extraction that would do nicely for a vacuum hold down.
Not sure if 1/4" ABS will cut very happily at router speeds, it tends to melt, but I think you will probably want router speeds for the other materials :nope:
If you whack a pen down with a solenoid it tends to dent the surface and deposit a blob of ink. The ink carries on down after the pen has stopped.
If you use a soft landing it takes more time. One speed solution is to use joined up writing
I used to be a service engineer working with Houston Instrument vinyl cutters, pen plotters etc. Gives you a rather jaded view if you only get to see them when they go wrong :whistling:
RFQ: Composite flat sheet cutting. (Water jet or router)
By carboncactus in forum Projects, Jobs & RequestsReplies: 0Last Post: 05-08-2013, 08:31 PM -
Holding down sheet material.
By jcb121 in forum Machine DiscussionReplies: 3Last Post: 03-07-2013, 12:11 AM -
Industrial router bed material
By D-man in forum General DiscussionReplies: 13Last Post: 23-10-2012, 01:43 PM -
CNC Routing Nylon 6 Material
By Steff in forum General DiscussionReplies: 5Last Post: 20-10-2012, 11:39 PM -
sourcing material for a DIY build
By mmcp42 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-01-2011, 10:23 PM
