Thread: N0VUSUN and Mitsubishi-D700-SC
OK, Ordered some diodes but have to wait for them,not the same since maplins closed...
jazz will i be able to control the speed via Mach3
10-04-2020 #2
Yes and turn it on/off. But you will need to set it up in the spindle control and set the outputs so can turn it on/off.
The manual should tell you how to do this because different controllers have different setups. If you can't find it or it's not obvious then let me know and I'll take a look.
Edit: you will also need to set the VFD up so it knows it's being controlled from an external source. Again the manual will tell you the parameters to set.
mitsubishi freqrol spindle drive
By dave498 in forum Spindles & Drive MotorsReplies: 1Last Post: 26-02-2015, 06:57 PM -
Mitsubishi E600 HMI
By birchy in forum General ElectronicsReplies: 10Last Post: 31-08-2013, 06:53 PM -
Mitsubishi FR-D700 Series VFD
By acollins in forum Motor Drivers & ControllersReplies: 4Last Post: 31-05-2012, 07:24 AM -
Installing Mitsubishi inverter FR-E520S-2.2K-EC
By Colin Barron in forum Motor Drivers & ControllersReplies: 5Last Post: 25-09-2010, 07:02 PM
