Thread: N0VUSUN and Mitsubishi-D700-SC
16-04-2020 #34
Thanks. The diode is correct.
I've not been clear enough in how to measure the voltage, but the bit that you've said that you get 2-3 volts across the relay when the spindle should be on... that means you're dropping 3 volts across the relay coil which at 650R (roughly what it should be, given Jazz's quote of 36mA draw current) gives a switching current of around 4.5mA - bottom end of the performance of the opto-isolator of the NVEM and certainly not enough to actuate the relay.
If you are prepared to PM me your address I'll pop a gadget in the post (it's just the PNP transistor set-up... but I'll test it works before posting). Or, if you're happy to source/wire one up yourself then go for it.
mitsubishi freqrol spindle drive
By dave498 in forum Spindles & Drive MotorsReplies: 1Last Post: 26-02-2015, 06:57 PM -
Mitsubishi E600 HMI
By birchy in forum General ElectronicsReplies: 10Last Post: 31-08-2013, 06:53 PM -
Mitsubishi FR-D700 Series VFD
By acollins in forum Motor Drivers & ControllersReplies: 4Last Post: 31-05-2012, 07:24 AM -
Installing Mitsubishi inverter FR-E520S-2.2K-EC
By Colin Barron in forum Motor Drivers & ControllersReplies: 5Last Post: 25-09-2010, 07:02 PM
