Thread: Ross CNC machine
10-04-2020 #1
Got my own small cnc/router that does aluminium quite well , but it’s stuck in France while I’m in New Zealand until the house is sold.
Just wondering if this machine I’ve found is capable of decent doc on aluminium . Asked the seller but no answer yet. Im guessing the machine is just designed for routing wood
https://www.trademe.co.nz/business-f...2591400243.htm
5 grand in sterling. Bit too exp for me but thought it wasn’t a bad price for a factory built machineSwedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
3 axis CNC/router / Alu profile frame....25mm Alu Cutting bed X=500mm Y=300mm Z=110mm.....Supported 25mm X rails ....Supported 20mm Y rails....Supported 20mm Z rails.....2.2kw Chinese WC spindle..... CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller....M542 Drivers..SY60STH86-3008BF Motors...running....Mach3 / Cambam / Emachineshop.
10-04-2020 #2
Could be crap, could be good. I would advise against it. I i was buying it would ask if structure is welded, what motors, drives, control, picture of the frame underneath the table, and so on.
Anyway, i wouldn't buy such a thing. God forbid me!
For that money you can buy a proper mill. Which is on another level, if you do metals or have a product, etc. Even small mill will be 100 times better
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
10-04-2020 #3
I understand that completely. My home built cnc router is pretty capable and cost me under a grand. Kind of liked the idea though but glad someone has talked some sense into me. I cant afford that sort of wedge anyhow
Newbie Machine Build Log (Fancy Machine)
By Fancy in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 18-09-2018, 06:15 PM -
Help please Retain mach 3 licence for my next machine when selling current machine
By suesi34e in forum Artsoft Mach (3 & 4)Replies: 10Last Post: 14-02-2018, 12:45 AM -
4Axis 0.8KW Router Engraving Machine Milling Drilling Engravor 3040 CNC Machine
By KeithElcomb in forum Chinese MachinesReplies: 0Last Post: 27-09-2017, 12:32 PM -
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM
