    Could be crap, could be good. I would advise against it. I i was buying it would ask if structure is welded, what motors, drives, control, picture of the frame underneath the table, and so on.
    Anyway, i wouldn't buy such a thing. God forbid me!
    For that money you can buy a proper mill. Which is on another level, if you do metals or have a product, etc. Even small mill will be 100 times better
  2. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  3. #2
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 06-06-2026 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    I understand that completely. My home built cnc router is pretty capable and cost me under a grand. Kind of liked the idea though but glad someone has talked some sense into me. I cant afford that sort of wedge anyhow
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
  1. Newbie Machine Build Log (Fancy Machine)
    By Fancy in forum Gantry/Router Machines & Building
    Last Post: 18-09-2018, 06:15 PM
  2. Replies: 10
    Last Post: 14-02-2018, 12:45 AM
  3. Replies: 0
  4. Replies: 0
