Thread: Steel tube build
12-04-2020 #6
I guess realy depends on what kind of job i am doing. When i cut general stuff and cleaning passes yes i cut at 7-10k mm min, but when i am fabricating for example the music instruments i am making i keep slow, because going fast chips edges from time to time and is very difficult to repair if at all, as size must be correct. So i dont speed then and cut at finishing speeds. As at the end of 3-4 days work if i have chipped say every five from 100 pieces it would be like 50 pieces to repair. Which is tremendous amount of time lost and material, if its unrepairable.
Same with the signs i make. I aim at perfect cut of Plexiglass or Dibond. The other day i cut PLexiglass and made a video, even wanted to post it here. 18k. spindle speed and 70 ipm/ at 0.5mm deep using 1/8 single flute. I played like 3 hours to find the perfect ratio. basically went to the conclusion that could go 2 times as fast and 3 times as deep, but from time to time there was crap on the bit and i had to be constantly there. Having in mind had to cut 8 hours and the material is 100e/m2 i have decided to go at said speeds and air blow from the fog mister and that let me have the job unattended. So simple.
PS i cut aluminum at 2k mm min also
Using stainless steel tube for linear bearings
By shoeswith in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 31-07-2017, 03:19 PM -
steel tube build concept - 1500y,1000x,250z
By outtastep in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 26-11-2015, 03:39 PM -
I need to build a tube profiling machine
By Paulgy80 in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 13-04-2014, 12:58 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
