When I had my Novamill, I made a tooling plate from some flat bar, with a bit gauge steel dowelled along the rear edge, then used MiteeBite edge clamps to hold lengths of flat bar in place.
There's a photo at https://www.flickr.com/photos/mc_mtb...n/photostream/
IIRC it was made from either 1/2" or 15mm bar to give enough depth for recessing the mounting boltsAvoiding the rubbish customer service from AluminiumWarehouse since July '13.
14-04-2020 #2
I like a fixture plate made with a grid of tapped holes with 1" centers. I find it's most versatile as it allows all kinds of fixtures and sub-fixtures or vices to be held. Can use dowels for stops and to push against using low-level clamps like Mitee bite, even on odd-shaped parts. You can bolt down strips of material and machine soft jaws which can then push against.
It can use standard fixture clamps with a lot more scope for finding a place to hold because you are not restricted to slots. Holding parts for full uninterrupted profile passes is easier because you can often all ways find a hole to bolt part down with which you can't always land on a slot.
You can hang it over the edge of the table and take full advantage of all the available travel with Clamps effectively outside the travel area. For instance, a 4th axis can be hung on the end and not rob any tablespace.
FOR SALE: Fixture plate
By GOOSEISLAND in forum Items For SaleReplies: 5Last Post: 05-06-2020, 03:34 PM -
Supplied size accuracy on tooling plate.....
By Voicecoil in forum Metalwork DiscussionReplies: 7Last Post: 01-10-2018, 08:34 AM -
Alloy 5083 Tooling plate Suitable for gantry build?
By PaisleyPCdoctor in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 20-01-2018, 07:05 PM -
eBay: 31 x Cat50 Tooling Kennametal, Sandvik Coromant Bristol Erickson milling machine cnc
By Fivetide in forum Items On eBay UKReplies: 0Last Post: 02-12-2016, 02:29 AM -
Problem milling extruded polystyrene (Styrofoam) solutions requested.
By marbles in forum General DiscussionReplies: 1Last Post: 23-08-2015, 12:39 PM
