    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 09-02-2025 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Just found this machine local ...Anybody know how involved it would be to convert into cnc mill please ?
    https://www.trademe.co.nz/business-f...b8e2b89c66-003
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
    Nope. I don't know how involved it'd be. It's a job that'd need proper lifting tackle before you even start, though. If you're craz.... enthusiastic enough to try this - please take photos!
    No different from converting any other knee mill, just a few plates and belts along with correct size motors. The spindle head will be limiting. However unless it's very cheap don't think I'd bother and look for something better.
    dudz's Avatar
    Might be wrong but i think its going to go for the starting price of 800 nzd (400 pounds) .Thats why i had my eye on it. there are some much better and newer mills here but over 5000 NZD. I cant work out what the spindle clearance is. Found some info but its not mentioned. http://www.lathes.co.uk/denbigh/
  1. [request][help][model making]
    By mdishaq123 in forum New Member Introductions
    Last Post: 31-08-2018, 04:27 PM
  2. FOR SALE: Boxford Model A Lathe
    By Chaz in forum Items For Sale
    Last Post: 03-09-2016, 02:27 PM
  3. RFQ: 3D Model
    By petesos in forum Projects, Jobs & Requests
    Last Post: 01-01-2013, 10:31 PM
  4. NEW MEMBER: Hi from Denbigh North Wales - Myford ML7 lathe conversion beginner
    By veedub1955 in forum New Member Introductions
    Last Post: 27-04-2012, 11:58 AM
