Thread: Denbigh model D conversion ?
Nope. I don't know how involved it'd be. It's a job that'd need proper lifting tackle before you even start, though. If you're craz.... enthusiastic enough to try this - please take photos!
13-04-2020 #2
No different from converting any other knee mill, just a few plates and belts along with correct size motors. The spindle head will be limiting. However unless it's very cheap don't think I'd bother and look for something better.
13-04-2020 #3
Might be wrong but i think its going to go for the starting price of 800 nzd (400 pounds) .Thats why i had my eye on it. there are some much better and newer mills here but over 5000 NZD. I cant work out what the spindle clearance is. Found some info but its not mentioned. http://www.lathes.co.uk/denbigh/
Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
[request][help][model making]
By mdishaq123 in forum New Member IntroductionsReplies: 2Last Post: 31-08-2018, 04:27 PM -
FOR SALE: Boxford Model A Lathe
By Chaz in forum Items For SaleReplies: 2Last Post: 03-09-2016, 02:27 PM -
RFQ: 3D Model
By petesos in forum Projects, Jobs & RequestsReplies: 3Last Post: 01-01-2013, 10:31 PM -
NEW MEMBER: Hi from Denbigh North Wales - Myford ML7 lathe conversion beginner
By veedub1955 in forum New Member IntroductionsReplies: 6Last Post: 27-04-2012, 11:58 AM
