Page 11 of 12 FirstFirst ... 9101112 LastLast
  1. #101
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Sounds more like some kind of hardware issue.
    I'd try swapping motors, then drives, to see if the problem moves or stays.
  2. #102
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 13 Hours Ago Has been a member for 8-9 years. Has a total post count of 484. Received thanks 81 times, giving thanks to others 26 times.
    Yes, I'd start swapping over the motor / encoder etc. Sounds like a buggered component or a wiring fault, crossed over wiring etc. Time to go for a process of elimination etc.
    IIRC, you fitted your own encoders. Getting those wired up correctly would be helpful. That must be a fairly likely candidate.
  3. #103
    I've attached a photo of the encoder just so you can verify it's even suitable for this application..
    So the encoder wiring is labelled up as:
    Brown: 5 - 24VDC
    Blue: 0V Common
    Shield: GND
    Black: OUT A
    White: OUT B
    Orange: OUT Z
    This is wired to the line driver module to convert to differential signals. I have attached a photo of the wiring info for this, but all it is is ground, A, 5 Volts, and B. so I have this wired up as:
    Ground: Blue: 0V Common
    A: Black: OUT A
    5 Volt: Brown: 5 - 24VDC
    B: White: OUT B
    From there it is just a standard RJ45 cable that plugs into the drive unit. I have also tested the cables I'm using with the proper tool to verify the wiring is correct.
    I have also attached the pin outs for the RJ45 side of the line driver and the servo drive encoder input.
ID:	28918   Click image for larger version.
ID:	28917   Click image for larger version.
Name:	line driver wiring.PNG
ID:	28919   Click image for larger version.
Name:	Servo Drive Encoder Wiring.PNG
  4. #104
    Just noticed after I posted that, looks like I may have the + and - the wrong way around on the A and B inputs from the line driver to the servo drive!
    EDIT: Would this actually cause any issues though? or just result in opposite rotation?
  5. #105
    Quote Originally Posted by JimJam View Post
    As long as you've still got the A/B paired correctly, direction is the only thing that could be affected.
  6. #106
    Muzzer's Avatar
    And as noted before, you need to be sure the cables don't cross over any of the conductors.
  7. #107
    Progress! You may remember a while ago I tried extending the encoder cables with some CAT5 cable I bought which turned out to be the cause of an earlier issue. I used the same cable to make up the RJ45 cables that link the encoders to the drives.
    I have no idea why I didn't replace these earlier when I had the other issue, but swapping them out for some bought patch cables has stopped the motor juddering..
    I stripped back the outer insulation of a piece of the cable from the reel and every now and then there is a break in the conductor but the insulation remains in tact! which I can only assume was enough to make a contact when I tested the cables but mounting it on the machine must have given it an intermittent connection.
    Now back to the tuning!
  8. #108
    Muzzer's Avatar
    Well I suppose a smart arse would point out that network cables aren't exactly industrial grade flexible cables, being single core etc. In my own defence, I only used it in my own system within the cabinet for the short distance between the line driver and the DG4S drive.
    Good you found the issue in the end. It could have been even more intermittent which would have been even more frustrating. With intermittent faults you can never be 100% certain you've found and fixed the issue.
    That cable sounds surprisingly crap if it has multiple breaks straight off the reel. You need to get the whole thing out of the building and into a skip where it belongs before you use any more of it now or in the future.
    That video of swarf can only be hours away now - looking forward to seeing it in action!
  9. #109
    Yeah, I’ve learnt my lesson there! Out of interest what would have been the best cable choice for this application?
    Is there flexible cable available that would work with the RJ45 plugs?
  10. #110
    Igus supply pretty much any kind of flexible cable you can think off, however you may want to be sat down when looking at some of the prices.
  11. The Following User Says Thank You to m_c For This Useful Post:
  1. eMachineShop Upgrade
    By Bladevane in forum CAD & CAM Software
    Last Post: 04-07-2025, 12:34 AM
  2. PC Upgrade Options?
    By Chaz in forum General Discussion
    Last Post: 31-08-2016, 04:53 PM
  3. Laser Upgrade
    By dcrowder in forum Laser Machines & Building
    Last Post: 06-05-2016, 01:06 PM
  4. VFD upgrade
    By paulus.v in forum Spindles & Drive Motors
    Last Post: 05-11-2014, 11:09 PM
  5. Upgrade
    By Dopy in forum General Discussion
    Last Post: 09-11-2011, 01:57 AM
