Thread: TOS-KURIM CNC Upgrade
You could try connecting the DRO encoders to a DC servo drive but unless you had near-zero backlash, the drive could be almost impossible to tune. This also assumes the encoder signal is a compatible (TTL A/B quadrature) type. If you have no backlash, it might be a workable solution.
Do the Indramat motors have encoders built in already? If not and the linear encoder doesn't work out, you'd need to fit a rotary encoder to each of the motors so the CNCdrives could work with them. You can buy suitable Haidenhain clone encoders from China for peanuts. Failing that, you'd probably be looking at acquiring some proper AC servos which would cost a lot more and need mechanical buggerage to fit them where the Indramats were. Not sure I'd want to waste my time and money fitting steppers to a decent machine like this.
Be aware that early analogue DC brushed systems often had tachometers mounted in the motors. They can't be used as encoders, as they only report speed, not position. However, you could remove them and use the freed up space to mount encoders.
17-04-2020 #2
Don't think these will be your typical magnetic linear encoders you see used on DRO's. These will be full blown Glass linear scales that are much more accurate and commonly used on high end machines.
If it was me I'd get the details of the Linear scales and drop CNCdrive an email asking if they can be used. I think they will be able to be used but you might need to convert from Single ended to Differential, which isn't a big issue. But they will be the one's to tell you, but they will need details.
Regards Steppers or Servo's then like I said if you want it cheap go with steppers as they will get the job done, maybe not as fast or smooth, but still done and reliable along with simple.!
eMachineShop Upgrade
By Bladevane in forum CAD & CAM SoftwareReplies: 184Last Post: 04-07-2025, 12:34 AM -
PC Upgrade Options?
By Chaz in forum General DiscussionReplies: 11Last Post: 31-08-2016, 04:53 PM -
Laser Upgrade
By dcrowder in forum Laser Machines & BuildingReplies: 8Last Post: 06-05-2016, 01:06 PM -
VFD upgrade
By paulus.v in forum Spindles & Drive MotorsReplies: 11Last Post: 05-11-2014, 11:09 PM -
Upgrade
By Dopy in forum General DiscussionReplies: 0Last Post: 09-11-2011, 01:57 AM
