Thread: TOS-KURIM CNC Upgrade
21-04-2020 #11
Bugger! turns out its 150Vac after all, so that will require some work as well! So with getting the DC output you need to use the centre tap and wire in some diodes or something like that?? to make a rectifier?? I've not done much in the way of electronics since my engineering apprenticeship if you couldn't tell! that was over 10 years ago and I didn't know that much then either!
Yeah I think I will try and get everything in the cabinet that's already on the side of the machine and then just use a laptop on a bench beside the machine for now. I did see someone had a nice setup with a mini PC in the cabinet and a touchscreen monitor mounted beside the machine, that looked like a nice setup which I may look into for a future project. Need to make sure I can get the thing working first though!
eMachineShop Upgrade
By Bladevane in forum CAD & CAM SoftwareReplies: 184Last Post: 04-07-2025, 12:34 AM -
PC Upgrade Options?
By Chaz in forum General DiscussionReplies: 11Last Post: 31-08-2016, 04:53 PM -
Laser Upgrade
By dcrowder in forum Laser Machines & BuildingReplies: 8Last Post: 06-05-2016, 01:06 PM -
VFD upgrade
By paulus.v in forum Spindles & Drive MotorsReplies: 11Last Post: 05-11-2014, 11:09 PM -
Upgrade
By Dopy in forum General DiscussionReplies: 0Last Post: 09-11-2011, 01:57 AM
