Thread: TOS-KURIM CNC Upgrade
28-09-2020 #31
Progress! You may remember a while ago I tried extending the encoder cables with some CAT5 cable I bought which turned out to be the cause of an earlier issue. I used the same cable to make up the RJ45 cables that link the encoders to the drives.
I have no idea why I didn't replace these earlier when I had the other issue, but swapping them out for some bought patch cables has stopped the motor juddering..
I stripped back the outer insulation of a piece of the cable from the reel and every now and then there is a break in the conductor but the insulation remains in tact! which I can only assume was enough to make a contact when I tested the cables but mounting it on the machine must have given it an intermittent connection.
Now back to the tuning!
eMachineShop Upgrade
By Bladevane in forum CAD & CAM SoftwareReplies: 184Last Post: 04-07-2025, 12:34 AM -
PC Upgrade Options?
By Chaz in forum General DiscussionReplies: 11Last Post: 31-08-2016, 04:53 PM -
Laser Upgrade
By dcrowder in forum Laser Machines & BuildingReplies: 8Last Post: 06-05-2016, 01:06 PM -
VFD upgrade
By paulus.v in forum Spindles & Drive MotorsReplies: 11Last Post: 05-11-2014, 11:09 PM -
Upgrade
By Dopy in forum General DiscussionReplies: 0Last Post: 09-11-2011, 01:57 AM
