Thread: TOS-KURIM CNC Upgrade
You weren't kidding, pricey stuff this flexible cable! If I ask nicely the electrical guys at my work might have an offcut of something suitable kicking around.. worth a try!
The motor didn't seem to be the issue in the end, I don't think anyway.
I was still getting the dimensional inaccuracy's when running a program so I went through the setup process again within UCCNC to define the steps/rev. This time I done it over a larger distance where as previously I just used the max travel of my DTI (only about 15mm), this time I just used the closest accurate thing I had at home (50mm slip gauge).
Running the program again, the dimensions were pretty good, 0.15mm of what was programmed, which is most likely backlash to be honest.
A few more test cuts and see what happens over larger/smaller lengths!
eMachineShop Upgrade
By Bladevane in forum CAD & CAM SoftwareReplies: 184Last Post: 04-07-2025, 12:34 AM -
PC Upgrade Options?
By Chaz in forum General DiscussionReplies: 11Last Post: 31-08-2016, 04:53 PM -
Laser Upgrade
By dcrowder in forum Laser Machines & BuildingReplies: 8Last Post: 06-05-2016, 01:06 PM -
VFD upgrade
By paulus.v in forum Spindles & Drive MotorsReplies: 11Last Post: 05-11-2014, 11:09 PM -
Upgrade
By Dopy in forum General DiscussionReplies: 0Last Post: 09-11-2011, 01:57 AM
