    Hi chaps. My last spindle died when a bearing went. I ordered what I hoped would be a direct replacement. But when it turned up the wiring is different. The spindle I had before had the wiring connector clipped onto the spindle. This new one as the wires inside a black box on the front. Inside the lid it states 330v, or 220v. There are three terminals and also an earth terminal. But I have know idea which of the three terminals to use. There are know instructions at all. I was hoping to keep using the original VFD to run the new spindle. The old spindle was 3.5kw, the new one is 4kw. Can anyone please help . Thanks
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 83 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by terry1956 View Post
    To be sure a picture of the connections would help plust a picture of the VFD wiring
    Hope these help, sorry I don’t have a very good camera
    Possibly a part number for the motor? the images are a little indistinct. Also part number of the VFD?
    The vfm is wired to the spindle, using terminals E,R,S. Inside the spindle cover is the following information. 220v, pin W2,U1. pin U2,V1. Pin V2,W1. And also. 330v. Pin W2 U1. pin U2,V1. pin V2,W1. None of which makes any sense to me at all.
    Can't advise at this stage without more info (see above) - it sounds as though you was wired for a single-phase motor and your new one is three phase, but I'm guessing an awful lot. Does the VFD have a R, S and T terminal? (it'd be good if it does and the new spindle is 3-phase)
    Can you take another pic of the black box without your hand holding it so that you can see the terminals
  1. Wiring of huanyang inverter and spindle
    By terry1956 in forum General Electronics
    Last Post: 12-11-2019, 05:47 PM
  2. chinese 500w spindle wiring
    By terry1956 in forum Spindles & Drive Motors
    Last Post: 14-01-2019, 11:52 PM
  3. VFD/Spindle wiring help
    By Davo242 in forum Spindles & Drive Motors
    Last Post: 28-12-2015, 10:33 PM
  4. Replies: 5
    Last Post: 29-09-2014, 02:42 PM
  5. VFD Cable and 2.2kw spindle wiring
    By Flamered in forum Spindles & Drive Motors
    Last Post: 24-08-2012, 07:29 PM
