16-04-2020 #3
Mach 3 doesn't get any feed back from the motors so it just assumes they are moving that's why the Dro's show movement. The BOB as probably disabled the outputs as per my other post.
Be very carefull when you are sticking probes into this area you can very easily fry those drives and what ever you do, DO NOT disconnect the motor connections from the drives while powered up or you will 99% destroy them. It's perfectly fine to power the drives without the motors attached but never remove the motor wires while drives are powered up.
New CNC build gantry questions
By Capsuna in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 04-12-2019, 12:59 AM -
BUILD LOG: 1800 x 1500 x 500 work area CNC build log
By marbles in forum DIY Router Build LogsReplies: 9Last Post: 17-10-2018, 01:53 PM -
Beginner MYCNCDIY Mill Build questions
By suraj1793 in forum Gantry/Router Machines & BuildingReplies: 35Last Post: 15-11-2014, 06:28 PM -
A few questions before I start my build
By eclassic in forum General DiscussionReplies: 0Last Post: 11-07-2011, 10:54 PM -
NEW MEMBER: Hi from rainy York - build plans/questions
By bikepete in forum New Member IntroductionsReplies: 13Last Post: 11-10-2009, 07:43 AM
