Thread: 3018 not moving
17-04-2020 #1
Hi, I’m a new boy to milling so I hope this isn’t a stupid question. I’ve bought a 3018 to try to learn about milling and CAD and at first everything was fine. It came with Candle Software and I engraved the three examples with no problems except for some vibration which I didn’t expect.
I’ve tried to use it jtoday but the X Y Z motors don’t move and the spindle doesn’t turn. There is also a whine coming from the control board that seems excessive, the cooling fan works quietly when powered by the usb so it’s only when using main power that I get the noise and vibration.
I’ve tried different COM ports but the connection seems a bit and miss,I’ve checked the wiring and the couplings motor to screw and found no obvious faults.
I would appreciate any help
17-04-2020 #2
I seem to have solved my issues. I have found there were duplicate copy’s of Candle and I believe they were conflicting, uninstalled and now running from CD. The noise and vibration problems stem from the pcb enclosure vibrating when the fan is under extra load.
Help with CNC 3018 from Banggood
By JeanB in forum Chinese MachinesReplies: 35Last Post: 04-12-2020, 05:40 AM -
3018 Pro has no connectivity on A5 pins.
By deepcut66 in forum Chinese MachinesReplies: 0Last Post: 29-02-2020, 10:48 AM -
3018 3 Axis Mini DIY CNC Router ONLY £125 with free shipping !!!
By Lee Roberts in forum Marketplace DiscussionReplies: 6Last Post: 09-01-2020, 09:00 PM -
3018 problem
By bazbalz in forum Machine DiscussionReplies: 8Last Post: 17-12-2019, 12:58 PM -
Help! Moving a big lathe...
By Jonathan in forum General DiscussionReplies: 21Last Post: 27-12-2015, 11:54 PM
