    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 06-06-2026 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Ok. Already had great success with my homebuilt cnc/router for milling billet. Now I have moved to NZ and cant get my machine for a fair while so planning on building another. Same Spec just bigger table, X and Y axis.
    Planning on a 650x650x150 cutting area
    This time I plan to use Hiwin linear rail instead of 25mm supported round rail. What size Linear should I be going with ? The bigger the better I suppose for rigidity ?
    I have been looking at ready made Z axis :
    https://www.aliexpress.com/item/4000...7%237558%23136
    Are these any good ? thought it might save me some time and money to buy it already assembled. Might do this for the Y axis also (If they do the length).
    Or are there better suppliers that anyone know of please ?
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
    3 axis CNC/router / Alu profile frame....25mm Alu Cutting bed X=500mm Y=300mm Z=110mm.....Supported 25mm X rails ....Supported 20mm Y rails....Supported 20mm Z rails.....2.2kw Chinese WC spindle..... CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller....M542 Drivers..SY60STH86-3008BF Motors...running....Mach3 / Cambam / Emachineshop.
