Thread: Lathe Reverse
  1. #31
    Do you have a dmv?
    It would help to measure resistance with bus bars of and capacitor disconnected
    Then we might get a clue on where the coils are connected.
    Verstuurd vanaf mijn SM-A505FN met Tapatalk
  2. The Following User Says Thank You to driftspin For This Useful Post:
  3. #32
    Lives in East Lothian, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,957. Received thanks 366 times, giving thanks to others 8 times.
    I just had another quick search, and this came up - http://www.sentridge.com/wp-content/...wiring_1ph.pdf
    It's not exactly like your wiring, however it should point you in the right direction, provided you work out how your coils are connected to your terminals.
    I'm a bit tired, but I think your main coil will be connected diagonally (middle left, to top right in your diagram), with one end of the secondary coil bottom right, and the other top left.
    If you remove all the jumpers, a quick test with a mutlimeter should confirm/reject that.
  4. The Following User Says Thank You to m_c For This Useful Post:
  5. #33
    That was a nightmare.... I had a dud contact on my (cheap as chips) rotary switch.
    I thought I was going mad, the logic had gone all twilight zone!
    I now have a lathe that works in forward and reverse.... CHEERS GUYS!
    It is just a simple case of moving the two jumpers / bus bars through 90 degrees on this motor (or adding a switch to do just that)
    Clarke Motor M80 BL4
Name:	Clarke Motor M80 BL4.jpg
    Cheers for the link M_C
    I had seen a few similar those but that was a good one!
    Driftspin: dmv?
    I was going to pull the motor out and measure all the winding wires but I thought I would give it one last run through as the logic seemed to be pointing to an strange anomaly or fault somewhere.
  6. #34
    Lives in Marple Stockport, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,342. Received thanks 618 times, giving thanks to others 82 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Glad you sorted it Mark
  7. The Following User Says Thank You to Clive S For This Useful Post:
  8. #35
    Driftspin: dmv?
    YES sorry, typo dvm.
    Digital volt meter.
  9. The Following User Says Thank You to driftspin For This Useful Post:
  1. Replaced faulty driver, now that axis runs in reverse
    By WRandall in forum Gantry/Router Machines & Building
    Last Post: 31-10-2018, 07:42 AM
  2. Dumb Reverse
    By Leadhead in forum General Discussion
    Last Post: 03-10-2016, 12:41 PM
  3. Reverse engineering
    By mikewatch in forum Probing, Digitizing & Scaning
    Last Post: 13-04-2013, 10:20 PM
  4. CNC style lathe home brew Lathe for drilling and cutting.
    By Bodge in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 18-04-2012, 10:45 AM
