Thread: Lathe Reverse
Most of that is rocket science to me... I get the general, gist I think.
I am running on the deduction that IF cap on pin2 = Forward and the cap on Pin4 = Reverse then the bus bars cannot be jumpered twixt Pin2 and Pin4 for reverse because that would eliminate any need to swap the cap from Pin2 to Pin4 so I have been unknowingly / randomly jumpering pins via the tumbler switch until I hit (1<----->2) + (3 <------> 4) where it will run in either direction depending only on the capacitor placement.
Having said that, I was 99% sure I had cracked the problem earlier and I was wrong so I'm going with 98% this time
This and other similar images had me convinced it was all in the bus bars.
I wont know for sure until Sat.
Replaced faulty driver, now that axis runs in reverse
By WRandall in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 31-10-2018, 07:42 AM -
Dumb Reverse
By Leadhead in forum General DiscussionReplies: 3Last Post: 03-10-2016, 12:41 PM -
Reverse engineering
By mikewatch in forum Probing, Digitizing & ScaningReplies: 1Last Post: 13-04-2013, 10:20 PM -
CNC style lathe home brew Lathe for drilling and cutting.
By Bodge in forum Lathes, Lathe Rebuilding & ConversionsReplies: 9Last Post: 18-04-2012, 10:45 AM
