    Hi all,
    Amateur here from near Huddersfield in Yorkshire. I have a mill from Axminster that I converted to CNC probably about 10 years ago. It was working ok but I've moved a couple of times since then and it probably hasn't run for about 6 years. It used to run on a PC with LinuxCNC and a 4 axis TB6560 board via the parallel port. With the lockdown in place I've been spending some time trying to get it running again, but
    a) The PC motherboard is dead
    b) The hard drive it dead
    c) The driver board blew up
    So.... I bought a TB6600 board a couple of years ago and I'm finally trying to get it running with a Raspberry Pi. I can't get the board to do anything so I am joining here to see if anyone can help. I'm off to post in the controllers forum now..
    Cheers,
    Kev.
    BDH's Avatar
    Lives in Mansfield, United Kingdom. Last Activity: 30-05-2021 Has been a member for 5-6 years. Has a total post count of 26. Received thanks 3 times, giving thanks to others 22 times.
    Hello Kev and welcome. I'm a bit further South of you in North Derbyshire.
    I'm afraid that I cannot help with your queries as I'm just coming to grips with CNC but I'm sure someone with help will be along soon.
    Brian
    EDIT: Welcome, I'll move my comment to your other post.
    I'm using m74hc08b1 AND gates to take the 3.3v as one input, 5v as the other input, and output 5v. I do have LinuxCNC running on the Pi, I can't find the exact instructions I used right now but check out here:
    https://gnipsel.com/linuxcnc/uspace/rpi4-rt.html
    Kitwn's Avatar
    Lives in Don, Tasmania, Australia. Last Activity: 3 Weeks Ago Has been a member for 7-8 years. Has a total post count of 984. Received thanks 118 times, giving thanks to others 52 times.
    Hi Kev,
    I've commented on your other thread.
    Kit
  1. NEW MEMBER: Hello from Yorkshire
    By RogerT in forum New Member Introductions
    Last Post: 21-11-2019, 03:59 AM
  2. NEW MEMBER: Hi from East Yorkshire
    By 1LegandOld in forum New Member Introductions
    Last Post: 09-12-2016, 10:17 AM
  3. NEW MEMBER: Hello from Yorkshire
    By ste68blue in forum New Member Introductions
    Last Post: 29-07-2009, 10:27 PM
  4. NEW MEMBER: Hi from Yorkshire
    By Graham in forum New Member Introductions
    Last Post: 28-04-2009, 01:39 AM
  5. NEW MEMBER: Hello from Yorkshire
    By potter1932 in forum New Member Introductions
    Last Post: 28-06-2008, 11:00 AM
