    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 16 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    Are the motors energised? - can you rotate them by hand with power off, and with power on - start at the basics.
    So, the answer is yes I could, so thanks for taking me right back there!
    After a bunch more messing around, including checking with an old printer cable and hooking up some prototyping wires, I discovered:
    a) It works through the LPT port
    b) It then worked with the GPIO port
    c) When I unplugged the printer cable it stopped working.
    I can still turn the motors when they're energised, but they are more 'clunky' than when not energised and a bit harder to turn.
    After even more messing around, I discovered that if you ground the appropriate LPT port pins to the same ground as the Pi, then the GPIO pins work!
    I have a bunch more to fix, but it's mostly software related so I'm off over to the LinuxCNC forum. I just wanted to post this here in case anyone else has the same board, and thank everyone for their help!
    Cheers,
    Kev.
  1. 5 axis breakout board and UC400eth query
    By Palletlad in forum General Electronics
    Last Post: 23-06-2019, 02:58 PM
  2. Csmio-IPM wiring A nema 17 TB6600 driver Z axis THC
    By Copypaste in forum CS-Lab (CSMIO)
    Last Post: 14-02-2019, 08:41 PM
  3. FOR SALE: 4 Axis CNC power distribution board - CNCPDB
    By TadasM in forum Items For Sale
    Last Post: 02-12-2017, 07:02 PM
  4. WANTED: Basic 3 Axis CNC breakout board.
    By Philly in forum Items Wanted
    Last Post: 29-09-2012, 10:39 PM
  5. easy cnc 3 axis control board
    By edgas10 in forum Motor Drivers & Controllers
    Last Post: 08-01-2011, 06:14 PM
