  1. #14
    cdag's Avatar
    Lives in Galway, Ireland. Last Activity: 27-04-2020 Has been a member for 4-5 years. Has a total post count of 2. Received thanks 1 times, giving thanks to others 0 times.
    Hi Stonelesscutter,
    I am based down in galway, i work with Aluminum alot and its uses and treatments. I would suggest that you draw up your design in cad if you have the facility and develop the pattern [ie solidworks sheet metal] and sub out to a local fabricator. What you are describing could easily be fabbed up with one of the many fabricators based in your locality and also powdercoated - for easily less than 400 and with a greater quality than what your will achieve by yourself. I would suggest making the corners chamfered rather than rouunded as all of that can be fabbed easily with a profile cutter and press brake. Hope this helps
    Best of luck
  2. The Following User Says Thank You to cdag For This Useful Post:
  1. CNC Cost per hour
    By bertthedog in forum General Discussion
    Last Post: 13-07-2020, 11:06 PM
  2. Looking For Cost Effective T Nuts
    By AlexDoran in forum General Discussion
    Last Post: 25-08-2017, 04:47 PM
  3. NEW MEMBER: Have investigated ways to make DOS based programs run on 64 bit computers
    By 64BitAndForwards in forum New Member Introductions
    Last Post: 26-01-2017, 04:43 PM
  4. RFQ: Cost request for cnc/routing.
    By Conan257 in forum Projects, Jobs & Requests
    Last Post: 28-04-2009, 10:55 PM
  5. 2 ways of mounting motor
    By Steve-m in forum Gantry/Router Machines & Building
    Last Post: 28-02-2009, 01:12 AM
