Thread: eBay router
Page 6 of 7 FirstFirst ... 4567 LastLast
  1. #51
    Lives in East Lothian, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Thanks, Moray, Quite a lot of time has gone into this project trying to get the best machine for the lowest budget, while at the same time making sure there's profit to make it worthwhile doing. So far I'm very happy with the design and the frames are rock solid, but the profit will remain to be seen...Lol
    The first batch won't be ready until Mid to late December and half of those are sold or spoken for already so the next batch if I do another, will be next year anyway.
    I've also got this little beast in the line up as well which I'm going to offer up. 500 x 500 x 350 Cut. Fixed gantry which is a little different in the gantry department.! It's built like the proverbial brick Sh#t house. I'm on with this one at the moment which is spoken for and will be ready in the next 3/4weeks so I'll take a video of it to show more. Another will follow it and be up for grabs.
    Attachment 28931 Attachment 28932
    Attachment 28933Attachment 28934
    Attachment 28935Attachment 28936 Attachment 28937
    That looks like a nice little machine, but I'm needing something that can handle metre long lumps of beech.
    Current situation depending, I'm hoping to spend a few days further south in the next couple months, so if it happens, I'll give you a shout.
  2. #52
    If it's long, narrow bits of beech you have in mind, like guitar necks for example, then taking that entire fixed gantry and putting it on rails might let you build a machine with a very stiff Z axis, though you might need control software that can do auto-squaring on two axes at once.
  3. #53
    Kit, that is next on the list. The design as been in the works for over a year but I keep scrapping it and starting again as I just can't make it work as I would like, but i think I've got it sussed now.
    Edit: Oh and doesn't need dual-axis motor slaving as the screws are connected with belts and use just one motor.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  4. #54
    Great minds eh? I realised about the belt drive about an hour after I wrote that. You can see the single motor in the pictures. I assume the long axis would be done the same.
    For long thin work that's going to be a very solid design and with the option of a fourth axis up the middle would be the bees knees for fancy furniture legs and a myriad of similar stuff. With the right gantry design you might be able to achieve an unusually high Z axis lift without seriously sacrificing rigidity which would help with that kind of work.
  5. #55
    Well a tear down for a creaking noise is proving interesting.
  6. #56
    It's not the best camera angle, but has that snapped, or have they shortened it with a hammer and chisel then buffed it grinder?
  7. #57
    Shortened yes but look at the bottoms right mounting hole also.
  8. #58
    You can see it better here
  9. #59
    I've seen a Chinese-built router where a lot of holes looked as if they had been drilled freehand, and the target for a proximity switch was a broken tap. Did have a locknut on it, though! And by the standards of these things, that was a fairly good router that's been doing a good job for a few years now. If that's what you find on a machine a step or two up, you realise that a few corners get cut to bring the price down. Cheaper to re-drill a stepper motor flange than scrap the badly drilled bit it bolts to?
  10. #60
    Another thing I see lurking in the back ground is where it mounts looks like there is no hole for the flange so it's sitting directly on the un-machined surface of the boss..!!
  1. 1300x 1300 router with vac bed on Ebay
    By Clive S in forum General Discussion
    Last Post: 30-01-2018, 03:57 PM
  2. ebay con
    By macca in forum Marketplace Discussion
    Last Post: 08-08-2014, 12:43 PM
  3. Ebay purchase of RECORD SCM 120 router
    By GEOFFREY in forum Machine Discussion
    Last Post: 06-07-2013, 06:07 PM
  4. Anyone ever bought a Router from China? (not ebay ones)
    By sly666 in forum Marketplace Discussion
    Last Post: 03-11-2012, 10:45 AM
  5. BUILD LOG: ebay score dwt cnc router
    By j4son in forum DIY Router Build Logs
    Last Post: 13-02-2010, 04:11 PM
