Thread: Rough cost for a CNC router
Interesting video.
If I could get the total time down to 10-15minutes per handle, I'd be happy, but it's just time consuming.
Screw the template on, and doing the trim on the bandsaw I estimated takes 5 minutes minimum.
Then profiling to the template is realistically 5 minutes, as my router table can't take that deep a cut as it's not rigid enough, so takes a bit finessing to avoid too many gouges.
Removing the template then rounding over takes another 5 minutes.
That's 15 minutes already, not including tool changes.
I machined 3 handles today, and it took me nearly an hour, including tool changes and tidying up afterwards (even with a good extractor, the router table throughs a lot on the floor).
Then even if I bought another router and made a jig/sled for thinning the ends, I'd estimate that'll be another 5 minutes.
So that's about 25 minutes per handle, and doesn't include time for sanding the handle to get rid of the ripples from the router table resonating/flexing, which is about 5-10 minutes per handle.
So even with everything as streamlined as possible, that's 30-35 minutes per handle.
If I switch to a CNC table, I guess labour input is likely to be around 5 minutes per handle, including swapping tools/blanks, if I can do 3 or 4 in one setup.
That's a 20 minute saving per handle. Plus there is the option I could probably switch to cut timber and have the router finish the surface, saving money on planed timber.
However, I need to workout if the labour saving will be worth the cost of building the machine.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Rough idea of costs to build a medium size router.
By jimbo_cnc in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 27-06-2014, 01:18 PM -
Boxford VMC190 Retrofit Problems, axis sounds very rough
By mikegolding in forum Boxford Vertical MillsReplies: 5Last Post: 09-06-2013, 09:11 PM -
rough traversing and stalling only in main screen
By davethefixer in forum Machine DiscussionReplies: 4Last Post: 12-05-2013, 08:34 AM -
torques - rough estimates for wrench ranges
By dsc in forum Machine DiscussionReplies: 2Last Post: 04-01-2013, 01:19 AM
