    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,990. Received thanks 374 times, giving thanks to others 9 times.
    4 x 2 I think is the smallest I would be willing to go, as it'll make it a more versatile machine.
    I was toying with the idea of making the gantry on the long axis, to leave room for future expansion, but in all honesty, I doubt I'll do much other work in wood.
    Cost I want to try and keep as low as reasonable, but would prefer to source in the UK for speed, but even if I decide to go ahead with this, it'll probably take me a couple weeks to get the frame built anyway (I've got a queue of other jobs I need clear out the shed first!), so that isn't set in stone.
    One thing I can't find much mention off, is what do you do about protecting the ballscrews?
    Or is it fine to leave them exposed, with regular lubrication?
    (my lathe had been used for wood when I got it, so I'm well aware of how sawdust can penetrate components!)
    Electrics is the bit I know the most about, it's just all the practicalities/mechanics of a woodworking machine I don't.
    They handle sawdust ok up to a point but as you know it does get in there eventually. Anything you can do to keep them out of the firing line helps which is why I put them under the table out of the way rather than stuck on the sides. The "L" shaped gantry puts the screw at the rear again out of the way.
    It's a simple proven design that doesn't require fancy guards or bellows etc and does a good job of protecting screws.
  1. Rough idea of costs to build a medium size router.
    By jimbo_cnc in forum Gantry/Router Machines & Building
    Last Post: 27-06-2014, 01:18 PM
  2. Boxford VMC190 Retrofit Problems, axis sounds very rough
    By mikegolding in forum Boxford Vertical Mills
    Last Post: 09-06-2013, 09:11 PM
  3. rough traversing and stalling only in main screen
    By davethefixer in forum Machine Discussion
    Last Post: 12-05-2013, 08:34 AM
  4. torques - rough estimates for wrench ranges
    By dsc in forum Machine Discussion
    Last Post: 04-01-2013, 01:19 AM
