Thread: Help needed
30-04-2020 #2
Clive, I don't think this will be the case. More likely the frame geometry.
Peter, If it is cutting squarely on the X-Y plane, then the easiest thing to do is put an MDF sacrificial bed on and machine it flat with a largish cutter. IF that produces a rippled surface, then your Z axis is not going squarely up and down, again geometry!
You are a lucky bugger to be in a position to order a new machine from Dean. I would if I could, but only so he would not be able to criticise it (not that I would expect it to have any flaws
01-05-2020 #3
01-05-2020 #4
If the cutter face isn't square to the bed, when you cut it will do an angled cut. The larger diameter cutter you use, the more the effect. This will make a sawtooth wave ripple on the bed and it is quite noticeable. the distance between the ridges will depend on stepover. I am assuming that you use a raster or spiral pattern, trochoidal will be less noticeable.
This error will also be noticed on the side walls of a deep cut.
01-05-2020 #5Clive, I don't think this will be the case. More likely the frame geometry.Is it out by 0.5mm over 200mm ? if so the steps per might be wrongYes you are correct Rob I was reading it as it was out from 400mm to 399mm and not the drop in ZSo I repented my error and got the Z axis within 0.02mm left to right. Just don't know how to correct the 1mm drop over 400m on the Y axis...Clive
Help needed
By terry1956 in forum General ElectronicsReplies: 5Last Post: 06-11-2018, 02:28 PM -
help needed with my set up
By amxen in forum General ElectronicsReplies: 20Last Post: 12-07-2018, 11:19 AM -
Help needed in Lincoln
By Edendale in forum General DiscussionReplies: 4Last Post: 31-03-2018, 07:12 PM -
a little more help needed
By terry1956 in forum Motor Drivers & ControllersReplies: 1Last Post: 29-02-2016, 05:52 PM -
PSU help needed
By John11668 in forum General ElectronicsReplies: 7Last Post: 04-11-2014, 12:21 PM
