Thread: Help needed
30-04-2020 #18
Clive, I don't think this will be the case. More likely the frame geometry.
Peter, If it is cutting squarely on the X-Y plane, then the easiest thing to do is put an MDF sacrificial bed on and machine it flat with a largish cutter. IF that produces a rippled surface, then your Z axis is not going squarely up and down, again geometry!
You are a lucky bugger to be in a position to order a new machine from Dean. I would if I could, but only so he would not be able to criticise it (not that I would expect it to have any flaws)
Help needed
By terry1956 in forum General ElectronicsReplies: 5Last Post: 06-11-2018, 02:28 PM -
help needed with my set up
By amxen in forum General ElectronicsReplies: 20Last Post: 12-07-2018, 11:19 AM -
Help needed in Lincoln
By Edendale in forum General DiscussionReplies: 4Last Post: 31-03-2018, 07:12 PM -
a little more help needed
By terry1956 in forum Motor Drivers & ControllersReplies: 1Last Post: 29-02-2016, 05:52 PM -
PSU help needed
By John11668 in forum General ElectronicsReplies: 7Last Post: 04-11-2014, 12:21 PM
