Thread: Help needed
29-04-2020 #11
I am grateful for your advice but I don't want to do the work. My time is better spent doing the stuff I know.
29-04-2020 #12
29-04-2020 #13
29-04-2020 #14
Ermm actually NO it's not, this is why you are having the problems.!!
Most on here are hobbyist and I'd say 99% of those who have a self built machine would outperform a merchant dice machine by a factor of at least 2x upto 10x +..!! . . . But your correct if it's for business then your best concentrating on what you know best and earns the money.!
29-04-2020 #15
Look folks - I don't want to nor do I intend to insult people. You don't have to spank me any further. I know I have a turkey on my hands!
I am a full time Artisan Ukulele Maker who happens to use a CNC machine bought in complete ignorance. Over the past 3 years it has achieved for me a great deal and added value to my work. I have abused it, mis-used and now push it to its limits machining hardwood with deep cuts using large diameter cutters!
Because of workload I just do not have time to go at this machine in a major way and furthermore, It is central to my current work and I have to have a working machine. So grateful as I am for the advice, my original post was for someone to come and do the repair/restoration for me. I neither have the technical capability or confidence to do it myself.
After speaking to Dean who kindly called me (mahalo Dean) I am now developing a project which will pay for a new machine soooo Dean, check your bt account - proposal in there.
30-04-2020 #16
So I repented my error and got the Z axis within 0.02mm left to right. Just don't know how to correct the 1mm drop over 400m on the Y axis. Good job `i am commissioning a new machine. Problem is I am asking my little machine to do tough work. Thanks for shaming me to get out the allen keys and dial gauge.
30-04-2020 #17
My MD demonstrated the downfall of unsupported rails - with the Y bowing under the weight of the gantry particularly in the centre of travel. Do you mean you're dropping 1mm from one end of Y to the other?, if you're bold enough it might be worth examining if, from the image of the router, the rails are attached to the end extrusions, whether you can release the bolts on the end extrusion and shimming it up to recover the lost 1mm. Just a thought.
30-04-2020 #18
30-04-2020 #19
Clive, I don't think this will be the case. More likely the frame geometry.
Peter, If it is cutting squarely on the X-Y plane, then the easiest thing to do is put an MDF sacrificial bed on and machine it flat with a largish cutter. IF that produces a rippled surface, then your Z axis is not going squarely up and down, again geometry!
You are a lucky bugger to be in a position to order a new machine from Dean. I would if I could, but only so he would not be able to criticise it (not that I would expect it to have any flaws
01-05-2020 #20
Help needed
By terry1956 in forum General ElectronicsReplies: 5Last Post: 06-11-2018, 02:28 PM -
help needed with my set up
By amxen in forum General ElectronicsReplies: 20Last Post: 12-07-2018, 11:19 AM -
Help needed in Lincoln
By Edendale in forum General DiscussionReplies: 4Last Post: 31-03-2018, 07:12 PM -
a little more help needed
By terry1956 in forum Motor Drivers & ControllersReplies: 1Last Post: 29-02-2016, 05:52 PM -
PSU help needed
By John11668 in forum General ElectronicsReplies: 7Last Post: 04-11-2014, 12:21 PM
