Thread: Help with tb6600 stepper driver
"stopping" = "swapping", and I guess from you images you mean your switches are set to ON/ON/OFF/ON/ON/OFF - 200ppr and 1.5Arms - feels quite "okay" ish. for a small sized motor.
What do you mean "screaming" - that sounds quite alarming however it also suggests that you have a tone associated with a pulsed signal(?, I'm trying to guess a lot here). Does the "screaming" only occur when trying to move an axis?, or when the motor is at rest?
Are you able to decouple the motor from the screw?, to understand if the noise is due to a stalled motor? - just enough to allow the motor to spin freely when not driving the axis.
Can you provide a photo with all wiring to the driver
Connecting UNO R3 AVR Module / Arduino CNC Shield to TB6600 for Nema23 stepper motors
By DaveZ in forum Control Hardware & SystemsReplies: 11Last Post: 14-09-2021, 09:33 AM -
WANTED: Conqueror Design stepper driver or stepper conversion board
By pistolknight in forum Items WantedReplies: 1Last Post: 25-05-2019, 11:57 AM -
Csmio-IPM wiring A nema 17 TB6600 driver Z axis THC
By Copypaste in forum CS-Lab (CSMIO)Replies: 0Last Post: 14-02-2019, 08:41 PM -
TB6600 + general drive and driver matching question
By CNCStudent in forum Motor Drivers & ControllersReplies: 17Last Post: 29-12-2014, 10:16 AM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM
