Page 2 of 2 FirstFirst 12
    Kitwn's Avatar
    Lives in Don, Tasmania, Australia. Last Activity: 4 Weeks Ago Has been a member for 7-8 years. Has a total post count of 985. Received thanks 118 times, giving thanks to others 52 times.
    Quote Originally Posted by devmonkey View Post
    Are we talking about bringing the gantry into plane with the bed or tramming the spindle so it is perpendicular to an already planar gantry? They are different things right?
    Both! By using the mean value or the difference between pairs of measurements you can adjust for different things.
    Kit
    Kitwn's Avatar
    Assuming you have got your gantry in plane already (helped by ensuring your long rails are planar to start with), I then use an iterative method to tram the spindle itself.
    1. Level the spoil board with a smallish (10mm) endmill. It will be slightly scalloped if your spindle is out of tram but this doesn't matter.
    2. Put a 90 degree bent bar in the spindle with a DTI on the end and sweep it across the bed, I used about a 200mm diameter sweep. This will give you the tramming error, correct the spindle by rotating it left or right / forwards backwards and then goto (1). Note that left/right has to be done at the spindle not by jacking up one of the gantry carriages or you will take the gantry out of plane. If you can't adjust the nod (forwards backwards) n the spindle then you can jack up the back or front of both gantry carriages equally.
    That is how I do it anyway, I do something very similar to tram my milling machine.
    Joe,
    Sorry about the previous short previous reply, I was away in Perth with limited time.
    I assumed the long, fixed rails (X axis for me) were straight and then made them planar with the aid of a precision spirit level. The 65mm square rails they sit on can be shimmed at each end for this.
    Using the wires gave me a reference plane based on the rails themselves without the step of skimming the base and using that with all the slight imperfections and ridges etc. that would produce.
    As I described in the method, by taking either the difference or the mean value of the readings from two wires, one each in front of and behind the gantry (with the probe arm aligned parallel to the X axis), I got data relating to the tilt of the gantry in two directions which were corrected by shimming either both ends of the ganrtry, front or back (to correct what you have aptly termed 'nod'), or just one end, front and back for what I've called 'tilt'. I also got data about the twist (variation of nod) of the gantry along it's length. This was corrected with shims under the rails.
    Once the above was sorted, the final measurement was made along a single wire with the probe aligned along the Y axis. This indicated the tilt of the spindle due to rotation of it's mounting on the back-plate.
    These measurements were able to separately show the tilt of the gantry itself and the tilt of the spindle axis due to rotation of it's mounting which I think was the jist of your question.
    I hope this clears things up.
  1. Joining wires or using connectors / junction boxes
    By chillybo in forum General Electronics
    Last Post: 18-04-2020, 04:56 PM
  2. Where Do The Wires Go ?
    By Kev2960 in forum Chinese Machines
    Last Post: 25-02-2017, 08:49 AM
  3. Where to buy a tramming tool in the UK
    By Mad Professor in forum Tool & Tooling Technology
    Last Post: 08-02-2013, 01:10 PM
  4. voltage on motor wires
    By phill05 in forum General Electronics
    Last Post: 11-02-2012, 03:43 PM
  5. Tramming round column MD30
    By irving2008 in forum Milling Machines, Builds & Conversions
    Last Post: 09-02-2009, 04:07 PM
