Thread: Help with tapered holes
Here one to try,
Example to draw a ER32 collet holder: Draw out your largest circle say 32mm dia within draw smaller circle say 25mm dia, draw another circle say 17mm Dia, draw a vertical line 9mm long starting top of largest circle down towards centre select and circular copy this say 400 times ( the more lines you copy the smoother the finish) x 360 degrees.
Select smallest circle "pocket toolpath" to full depth say 36mm,, select all circular copied lines "Fluting tool path" run preview job done.
Hope it helps.
Phill
The Following User Says Thank You to phill05 For This Useful Post:
Drilling holes on cnc
By dfox1787 in forum Machine DiscussionReplies: 27Last Post: 26-05-2018, 05:21 PM -
Tapping holes
By JOGARA in forum Tool & Tooling TechnologyReplies: 4Last Post: 24-05-2018, 08:24 PM -
4.3 mm holes, 20 mm deep
By Chaz in forum Metalwork DiscussionReplies: 26Last Post: 08-08-2017, 10:46 PM -
Input Amana Tool Tapered Ballnose Settings into Vectric
By toby in forum VectricReplies: 6Last Post: 10-09-2016, 08:54 PM -
Drilling Ø0.2mm holes on aluminium
By hoezap in forum Metalwork DiscussionReplies: 5Last Post: 09-04-2016, 06:28 PM
