Thread: Fixed Gantry machine design tips
10-05-2020 #8
The other reason i dont like long and wide for that matter Fixed gantry, is that the table that moves has to ve sturdy and the only solution there is a very expensive aluminum plate, while you can throw anything you have at hand for the bed . Also a protection should be done for the ballscrews
And as the table grows, the motors will grow and the machine will grow slower.
Not a problem though if you will be cutting metal mainly
I still believe the Z is the most important thing, not only the gantry , if gantry properly made. And i can prove it to anybody how a 2 meter wide gantry cuts up to mild steel with mirror like finish. And aluminum like butter.
BUILD LOG: Possible Fixed Gantry build
By ericks in forum DIY Router Build LogsReplies: 0Last Post: 05-05-2020, 05:02 PM -
Fixed Gantry Design - Input Appreciated.
By Electroconducive in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 02-03-2017, 02:50 PM -
Fixed z axis to gantry design
By Lachlan in forum Gantry/Router Machines & BuildingReplies: 21Last Post: 20-10-2015, 09:50 PM -
Garage CNC - A gantry style machine design
By fandango in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 21-03-2014, 01:38 AM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM
