Since my lathe is currently out of action, I'm looking for a batch off 30 parts made to buy me some breathing space.
They're made from 20mm bar, need the outside turned to 19.5mm with a slight taper, an 8mm hole all the way through, and one end bored to a bit over 15mm and 15mm deep. Then parted off at 30mm.
I don't actually have a drawing for this part, as the original g-code was done using Mach 3 wizards from a sketch many years ago, but will get one made.
I can supply the bar, along with an 8mm stub drill, and drill turn tool if needed.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
RFQ: Aluminium horn CNC Lathe - 25-50 quantity, 75mm long, max 30mm diameter.
By JOGARA in forum Projects, Jobs & RequestsReplies: 0Last Post: 12-05-2018, 11:34 AM -
RFQ: Small round of aluminium cases. Small parts, 50 in total for first batch. 110x50x15m
By JOGARA in forum Projects, Jobs & RequestsReplies: 0Last Post: 07-05-2018, 07:18 PM -
FOR SALE: Batch of 3 6082/T6 Aluminium Plates
By Solihull1 in forum Items For SaleReplies: 3Last Post: 26-02-2015, 10:04 PM -
Optimal ballscrew diameter for lathe
By vre in forum Lathes, Lathe Rebuilding & ConversionsReplies: 6Last Post: 20-03-2014, 02:44 AM -
Sieg Mini lathe - smallest diameter rod turn-able?
By HankMcSpank in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 18-11-2010, 01:15 PM
