11-10-2020 #1
Hi guys,
My gantry left motor started switching off recently. Long story short after disassembled and checked cables, rotating ballnut and so, narrowed it down to stucked servo motor. Rotates very difficult and is grinding like.
400w Samsung AC 230v servo. Should I open try to repair, search for a dedicated repair center o just buy another one/ used/. Of course a job is waiting to be done from 2 days ago...
Motor obviously works, I assume switches off from over current and heat.
Whats your opinion?
Hi Boyan
Machine is down with customer waiting, fix it yourself should be quickest option, get it off today get bearings Monday if there's an encoder on the back end take that cover off first to ensure it doesn't get damaged if you can't get an exact match for the bearing number get one that is dimentionally the same(obviously) and you can start using the machine again until you can get the correct bearing.
Regards
Mike
13-10-2020 #3
28-10-2020 #4
28-10-2020 #5
Only problem I've had buying CNC parts from South Korea (was a set of linear rails and carriages) - the vendor was too damned honest on the customs declaration form and I had to spend half as much again on import duty/taxes/handling.
29-10-2020 #6
29-10-2020 #7
Recommendations for stepper motor debug / repair
By Cotswold Woody in forum Stepper & Servo MotorsReplies: 16Last Post: 05-08-2018, 07:07 PM -
AC servo motor help !
By rnr107 in forum Stepper & Servo MotorsReplies: 35Last Post: 10-08-2015, 02:37 PM -
eBay: SEM SERVO MOTOR SEM MT30 U4-48, LAMBDA psu,s, 160v servo drive
By dazza in forum Items On eBay UKReplies: 0Last Post: 29-01-2015, 08:55 AM -
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
servo motor as spindle motor
By Scott in forum General DiscussionReplies: 1Last Post: 03-10-2010, 06:42 PM
