05-10-2020 #15
Does your controller give a rough schematic of the input circuitry? The ones that I've seen had the "differential" input simply going to the diode side of the optoisolators with an antiparallel diode and a small series resistor. If so, driving it single ended is no problem, though if it were me (and since you already have it wired up with twisted pair) I'd do the grounding of PP- back at the BOB.
Options for replacement lathe spindle motor
By Doddy in forum Spindles & Drive MotorsReplies: 13Last Post: 16-05-2021, 07:47 AM -
lathe dc servo motor brake/spindle lock ??
By dazza in forum Lathes, Lathe Rebuilding & ConversionsReplies: 0Last Post: 01-11-2014, 05:22 PM -
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
2.2kw servo motor for spindle
By blayde in forum Spindles & Drive MotorsReplies: 1Last Post: 01-01-2014, 04:48 AM -
servo motor as spindle motor
By Scott in forum General DiscussionReplies: 1Last Post: 03-10-2010, 06:42 PM
