05-10-2020 #18
No, generally a single ended driver just sinks current. When you turn it off, the current into the driver stops. If there is a decent capacitance in / around the opto LED, it takes a few hundred nanoseconds to actually turn off completely.
The differential line driver (RS485 etc) both sinks and sources current by swapping the polarity over using a totem pole output stage. So generally you have a choice between a sink-only single-ended driver or a full sink-source differential driver.
It's a pity the current solution already uses differential drivers. Do both sides of the driver output still work? Or is the failure due to perhaps one of the lines no longer switching? It's possible that might explain why it bursts into life when the scope grounds one side.
Options for replacement lathe spindle motor
By Doddy in forum Spindles & Drive MotorsReplies: 13Last Post: 16-05-2021, 07:47 AM -
lathe dc servo motor brake/spindle lock ??
By dazza in forum Lathes, Lathe Rebuilding & ConversionsReplies: 0Last Post: 01-11-2014, 05:22 PM -
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
2.2kw servo motor for spindle
By blayde in forum Spindles & Drive MotorsReplies: 1Last Post: 01-01-2014, 04:48 AM -
servo motor as spindle motor
By Scott in forum General DiscussionReplies: 1Last Post: 03-10-2010, 06:42 PM
