I scoped it last night with 2 channels in differential mode and the output from the 485 were sweet (common mode noise all gone), particularly compared against the single ended measure (full of noise). Also, last night, changed the kernel frequency of the uc300 to 50khz to increase the pulse width to 10us (at 100khz kernel the pw is a rather narrow 5us).
The thing that gets me is that this was working fine. Going single ended feels an inferior move than differential driven)... unless one of the 485 outputs is starting to fail hi-z.
Equivalent input circuit is as you describe, opto, reverse diode and series resistor -330R
05-10-2020 #2
05-10-2020 #3
At the '485 board, which meant resting the scope on a bin, and leaning over the horizontal band saw whilst trying to set the math function up on a scope with a crap rotary encoder for the function setting. The waveforms were pretty much 5Vpk-pk though I wasn't really paying too much attention to that. Call it 2 and a bit divisions, and cramp in my calf.
Options for replacement lathe spindle motor
By Doddy in forum Spindles & Drive MotorsReplies: 13Last Post: 16-05-2021, 07:47 AM -
lathe dc servo motor brake/spindle lock ??
By dazza in forum Lathes, Lathe Rebuilding & ConversionsReplies: 0Last Post: 01-11-2014, 05:22 PM -
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
2.2kw servo motor for spindle
By blayde in forum Spindles & Drive MotorsReplies: 1Last Post: 01-01-2014, 04:48 AM -
servo motor as spindle motor
By Scott in forum General DiscussionReplies: 1Last Post: 03-10-2010, 06:42 PM
