Thread: CNC work needed
Hi all.
Please excuse if not the right forum category.
I am looking to get a price for an initial bit of small cnc work.
Essentially, I am looking for someone with very accurate work, to be able to route the following:
1. Frame edging on left hand side (swirls, curves from 1-4 mm wide and 4 mm deep)
2. A rectangle 5mm deep at 6x4"
3. An inner portion of the same rectangle, 7mm deep leaving a 4mm lip around the edge
4. A cross (crucifix) approximately 20mm wide, 7mm deep
5. A selection of words:
Line 1: Congratulations
Line 2: (Persons name) up to 22 letters
Line 3: Christened today
Line 4: Date in following format 11-05-2020
See attached sketch.
Product is made from 30mm glued Cedar boards 450mm x 210mm planed and smoothed to 500 grit.
Am looking for costs and if acceptable, will be asked to produce the work for each of our orders
Can't Get my New Machine to work
By Kev2960 in forum Chinese MachinesReplies: 12Last Post: 11-01-2020, 01:36 PM -
Harrison Alpha 330 lathe Fanuc 21it Work offset and Work shift problems
By Sucram in forum General DiscussionReplies: 0Last Post: 15-12-2019, 09:44 PM -
4th Axis Work Holding For Rectangular Work
By magicniner in forum Workshop & EquipmentReplies: 1Last Post: 20-10-2019, 03:02 AM -
RFQ: flat work needed
By kristof in forum Projects, Jobs & RequestsReplies: 7Last Post: 24-11-2012, 12:00 PM -
RFQ: Flat work needed
By Ricardoco in forum Projects, Jobs & RequestsReplies: 6Last Post: 29-07-2012, 01:44 PM
