I think this should be a simple 3d shape to cut I'm using Fusion 360 to cut a very simple flat triangle with a 72deg chamfer on 2 edges - the idea is to cut 5 which will then be stuck together to make a pentagon pyramid.
the whole thing is quite small (25 mm from base to point) and I'm using a 1mm flat bit - I went for a 3d contour and it generates to toolpaths except for 2 very annoying things.
I selected 3d contour and used the top and bottom contours to cut to and I have 2 problems
1/ the cut doesn't go all the way down to the bottom contour
2/ It won't cut along the vertical (short side) -I've tried using other modes with the same result
I'm clearly setting something wrong in using contour (I've only used it in 2d mode before) - can anyone help me with what I'm dong wrong ??
I tried earlier to submit this query but it didn't seem to work - apologies if I've posted twice by accident
