14-05-2020 #18
Zip up the G-code file and post it. The G-code should tell you everything.? If it says 15.6mm in the code and you have touched the tool off correctly then the length of the tool makes no difference provided it's longer than 15.6mm and you have Z travel enough it should go through the material.! If not then it can only really be slipping in the collet because the other tools are cutting correctly so it's not a mechanical or controller issue.
Email: [email protected]
Web site: www.jazzcnc.co.uk
FOR SALE: CNC Router Parts 2448 full set up with laptop, 2x4ft bed
By SuperSeb in forum Items For SaleReplies: 0Last Post: 11-11-2019, 08:54 AM -
Way out of my depth
By jenxmetalworks in forum New Member IntroductionsReplies: 18Last Post: 17-03-2017, 07:42 PM -
FOR SALE: Boxford 160tcl Lathe and 260 vmc milling machine with full boxford software for sale
By Waine in forum Items For SaleReplies: 2Last Post: 21-04-2016, 09:18 AM -
solidoworks tapped thread depth and blind hole depth
By reefy86 in forum CAD & CAM SoftwareReplies: 2Last Post: 10-11-2015, 04:14 PM -
CNC milling machine full support required
By Rebekah_harper in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 26-05-2012, 10:57 PM
