    Anybody experience with these?
    It looks like a neat way to cut down on parts but I wonder if it's going to cope properly with axial loads?
    A proper BK bearing block has two captive bearings and a nut that holds it all together. I'm not so sure about these?
    I do note the specs state a different load for axial push and pull, might be a clue?
    https://www.aliexpress.com/item/4000151063765.html
    Wal's Avatar
    Hmm... 4 wires, you won't be able to run this parallel bi-polar (faster but needing more current for torque) - I imagine it'll be little use in a CNC machine that you want to use like you half mean it. Half the holding torque of a motor you could buy on these shores for 30-odd quid...
    Probably ok in a 3D printer - I'd avoid it in a router.
    Yes, it's a way of saving on parts - but in reality you're talking about losing a handful of components which, arguably, allow you to build a more elegant machine. Despite this appearing to be a good idea, I imagine it would be quite cumbersome to build around...
    Just my uninformed opinion!
    Wal.
    I would agree with Wal. Don't touch a router with it but fine for a 3D printer. Save your money. I run when I see adds that say 100% Actual photos, 100% copper coil.... Eahhhh Yer grand. The bearings would not be up to much in that thing.
    I'm making a 3D printer. But I've gone with proper BK BF blocks and ball screws on the Y and X axis. Gone with integrated lead screw (not ball screw) motors for the Z axis. Simply because it was physically difficult to mount separate blocks for the Z axis. Lead screws are not that precise anyway so...
    Simon
  1. Just Motion Control integrated stepper motors?
    By boldford in forum General Discussion
    Last Post: 25-04-2020, 06:45 PM
  2. WANTED: Conqueror Design stepper driver or stepper conversion board
    By pistolknight in forum Items Wanted
    Last Post: 25-05-2019, 11:57 AM
  3. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  4. Stepper - ballscrew loading
    By Ricardoco in forum Gantry/Router Machines & Building
    Last Post: 22-06-2012, 07:46 PM
  5. Integrated stepper motors
    By Leadshine-Erci in forum Stepper & Servo Motors
    Last Post: 25-05-2012, 08:26 AM
