16-05-2020 #2
I'd ONLY fit an Ethernet controller, stay Away from USB it's flaky.
UC300 is the one I'd go for these days if running Mach3. Normally I'd recommend CSlabs controllers because they are superior in build quality and reliabilty but they are not supporting Mach3 any more and don't seem interested if you have a problem. The UC300 as more than enough I/O for most machines and works well enough with mach3, it also as it's own softwate UCCNC which works much better than Mach3 now and is still supported. Fit it to a decent BOB like the UB1 and your sorted.!
At those sizes then your into Nema 34 motors.
These are what I use and they are brilliant, they are 3 phase steppers so higher resolution with 1.2 Deg step angle compared to 1.8 of 2 phase motors and more powerful.
They are easy to setup and wire, and very reliable. I've fitted in excess of 100 sets and not had one faulty or give me trouble in any way. They run on Mains voltage so you don't need a PSU and being high voltage they allow high RPM which you wouldn't get from lower voltage DC motors.
https://www.aliexpress.com/item/3279...13616f37ZeokDw
Don't be afraid of China, I've bought from them for years and rarely do I have any issues. The suppliers I recommend are all well proven and trusted suppliers.
It's not true that it takes Weeks or Months, I've had stuff arrive in 4 days, but typically when times are normal.!! it's 2-3wks max if comes via Air freight and often that's because it's stuck in UK customs for a week. Also you know exactly what the charges will be, typically you pay VAT and a Ripp off paperwork fee from Shipping agent between £10-20. However, some parts can be subject to import duty and this depends on what category it falls into, but still you can find out exactly what the charge will be by going to Customs site and finding the import code.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
WANTED: Motor. Servo maybe stepper
By graffian in forum Items WantedReplies: 3Last Post: 24-05-2019, 01:50 AM -
FOR SALE: Parts For Sale - Servo Drives, Controller, 3Kw Motor, Transformers
By MrBurns in forum Items For SaleReplies: 0Last Post: 27-01-2017, 06:13 PM -
advise options needed on laser upgrade/add on
By george uk in forum Laser Machines & BuildingReplies: 9Last Post: 19-07-2014, 10:54 PM -
How can I find fast stepper motor / controller combo?
By JuKu in forum Stepper & Servo MotorsReplies: 2Last Post: 23-07-2013, 12:32 PM -
FOR SALE: Servo motor with 26:1 Gear box, EPOS controller and Power shunt unit
By Jimmybristol in forum Items For SaleReplies: 1Last Post: 30-05-2011, 11:03 PM
